Hi there, first time post; long time reader
I'm a electronic music producer and it's time to upgrade my studio pc. I usually use a laptop (Dell Inspiron 9300, tricked out) as I work abroad a lot (Asia, Europe and Australia). This time however, I want to build a normal desktop pc and buy (and keep) an LCD screen, keyboard and mouse in each of the countries I stay in. So that said, these are my requirements:
- Decent CPU (fast C2D or better)
- Potential to upgrade/overclock CPU (upgrade to Quadcore or better)
- At least one PCI slot (I use an expensive PCI 32bit soundcard)
- As light, small and portable as possible
- Integrated graphics with potential to upgrade to a decent'ish gaming graphics card sometime in the future
- Cheap!
Having looked at the Mac Mini (no PCI, no quadcore upgrade path) and various u-itx variants (expensive mobile processors; no quadcore) I've decided on a mini-atx desktop or a Shuttle PC. I've not been able to find a mini-atx case small enough so this is the Shuttle PC I've spec'd so far:
Few questions:
- Is the RAM and CPU suitable for this particular Shuttle PC motherboard? (cooling, spec and compatibility-wise)
- Ignoring the display, graphics card and hard disk for a moment, should I be looking at a different cpu, case, motherboard or ram for any reason? (better value, faster, easier to overclock, etc)
- If I were to buy a C2D processor instead of the 6600; what's the best bang for buck?
- Am I going about this all wrong and should be looking at a mini-atx case/system instead? If so, can you link me to some small cases that'd be similar to my required spec. (the case should be no bigger than the Shuttle PC case).
Thanks in advance for any help or advice
- Cheap!
Few questions:
