quite pc
2 Aug 2006
Liverpool
quiet pc
will this pc be quiet
case: Koolance PC4-1025SL '1000W' Lian Li V1000 Aluminium Tower - Silver
motherboard: EVGA 122-CK-NF68 NF680i SLI, S775, PCI-E(x16), DDR2 1200/533/667/800, SATA II, SATA RAID, ATX + Game
processor: Intel Core 2 Duo E6600, Socket 775, 2.4 GHz, 1066MHz FSB, Conroe Core, 4MB Cache, Retail
ram: OCZ® Platinum Series 2GB DDR2 PC6400 800Mhz, Dual Channel Kit with Platinum Heatspreader
psu: Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
graphics card: BFG GeForce 8800 GTX OC 768MB Silent WaterCooled GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Quite what?
Guessing you mean quiet, in that case we need to know what fans/cooling you will be using.
Cheers,
Sam C
Quite what? Quite good - yes. Quite fast - yes. Quite quiet - yes.
You'll need a CPU cooler. A Tuniq Tower would be a good bet, although I don't know how they rate for quiet levels. But they are damn good at cooling. The Zalman 9700 is supposed to be a pretty quiet cooler, but I think it's on the same level as the Tuniq. And the Tuniq does a better job of cooling.
Are you going to go SLI in near future? If not, another mbd might be a better choice, such as the Asus P5W64-WS Pro.
From what I've read, the Lian Li S80 is more quiet than the V1000.
The PSU really is overkill I'd say. The Corsair HX 620W would be a better choice given your setup, and it's a very quiet one.
Fans are probably the most crucial element though. The Scythe's are considered one of the most quiet at the moment.
