QX6700 testing
11 Jul 2003
Telford//west mids
Did a bit of overclocking last nite on my cpu :D
Cpu volts in bios 1.44v
Ram 2.30v
cpu temp in bios 49c.
http://valid.x86-secret.com/show_oc.php?id=152170
This is on air cooling :)
Awesome clock speed, however i see 15sec at spi 1m :\, is it just me? or is that a bit slow, i managed to do 14,5 on a 3,5ghz conroe :confused:
Slack ram timings ;) If they were tighter,you would see an improvement in spi
Orthos didnt try it was only testing to see what i could get it booted in windows,dont forget this is on air fan on 2000 rpm not water :D
I know nowit about ram,only thing i do is up the volts and fsb.
Its because you have pretty slack ram timings,can't you tighten them up a bit ?
Are your dominators not rated @ 5-5-5-15 ? You have yours @ 5-6-6-20,looking at the screenies
Rob
No point really as i was just messing around with the cpu to see how far i could push it,running back at stock now,as these push out more heat i backed off @ 3.8ghz :(
turboshed said:
it would be nice to see how far it would go with water cooling or even a phase changer :p
Aye sold my mach 2 gt a while back :( still under water it would do well i think.
