Jay_t said:I second that. I bought a Tuniq Tower to see if it was much better than the Zalman 9500. I sent it back after the thumbscrew fell to bits in my hand.A near 1kg heatsink hanging over an expensive graphics card with dodgy thumbscrews just wasn't my idea of fun. The lapping on it is terrible too, while you can see your face reflected by the Zalman. Zalman have just bought out a bigger 9700 cooler which must be about on par with the Tuniq Tower for overall cooling without the hassle.
Combat squirrel said:The screws on your TT fell apart as well ?that happened to mine as well !
I ended up going B n Q get me some standard screws and bolting it on manually to my opty, as tight as I dare to do it, seems there screws are bloomin rubbish, NOT good
On the + side manually bolting it on has ment I can get it much tighter so its like 27 idle, 40 load on opteron at 2.7ghz![]()
Flanno said:Same here. I have installed this cooler 3 times, on the 3rd got the absolute tightest fit possible as I completely took the mobo out so I could get at all 4 sides freely. Wondering how they actually snapped. They seem pretty sturdy to me. Did you overtighten them or something ?
CBP said:What happened to the thumb screws then? Did they just snap in the middle of the thread?
Not had a problem with mine, and mine's pretty tight
Jay_t said:Just because yours looks fine now doesn't meen that the screws won't fall apart someday.![]()
