I have a QX9650, and want to know how far I can “safely” push this on “Air” (Got Tuniq tower as cooler). I’m very much a novice in over clocking, but I’ve been having a look at it just recently, as this CPU has the ability (I believe) to go very high on air.
My motherboard is a striker II formula, and the settings/templates in bios for overclocking are “Quad 9770”, (3.2) and then ”Crazy”(3.51). Volts are set to 1.32 at these settings. Totally stable with these clocks (prime95 passed/Vantage fine, and 3dmark 06) – as you’d probably expect. But I feel I can get higher than this, but don’t want to “bork it” – as I’m a new as far as overclocking’s concerned.
Last night I got a Stable 3.833Ghz (11.5 multi/stock FSB @1333), BUT, I had to up the voltages to 1.39xx (next voltage increase was 1.4 – and I read on Intel’s site that 1.36xx is maximum for this CPU). Is this a safe voltage? Seen people on sites go 1.55 etc. with 5+ gigs
on clocks (Water cooled or perhaps nitro)
As regards the template/default overclocking that you set with the overclocking in BIOS, it sets the multiplier at default (9x), but the FSB at 1550 (but only 1.32 volts). What’s the best?, increased multi/&Voltage, *OR* higher FSB lower multi (9x), and lower Voltage? Won’t do 400x10, tried it. There are so many permutations, but not sure which one to go for. But as above, it is stable on 3.833 but with 1.39 volts
Cheers
Other specs: 4Gig (4X1) Tracer balistics RAM (1066) GTX8800x2 in SLI.(180.20drivers) Bios version 1501,Vista 64BIT, with XP pro on separate partition, 850 watt psu (OCZ gamestream)
~Ant
on clocks (Water cooled or perhaps nitro)As regards the template/default overclocking that you set with the overclocking in BIOS, it sets the multiplier at default (9x), but the FSB at 1550 (but only 1.32 volts). What’s the best?, increased multi/&Voltage, *OR* higher FSB lower multi (9x), and lower Voltage? Won’t do 400x10, tried it. There are so many permutations, but not sure which one to go for. But as above, it is stable on 3.833 but with 1.39 volts
Cheers
~Ant
