QX9650 temp and fan too fast/noisy
21 Jan 2008
Northwood, London
I have ran Core Temp and have temps 42,41,37 and 43(not O/C'd) at idle, is that ok, aswell as that I have a Zalman CNPS9711-NT Fan(only 4 months old), at the moment it is running very fast/full speed whilst playing games(don't know temps at full load), I have even changed the settings to Q-Fan Mode in the BIOS, this has no effect, is there something I can do about that(unless I'm not correctly using Speedfan properly) what would the "worst case scenario" be, buying a new fan, and could someone recommend one, price no problem.
You do know about the little black switch on the cooler, for normal/aircraft taking off settings? ;)
Hey dr sarf, If there is a switch I can't see it, and I have ran my fingers around the cooler, will I have to unscrew it to move the switch. btw the post should have read 9700-NT
Stop, my bad. :(
Thought you had the stock extreme cooler. :S
Can you run Prime95 on your PC and monitor the temps while doing so? (use coretemp)
I'm right in thinking fan speed is stepping up during games?
I've not actually ran prime 95 yet, but will do so and get back asap.
I do actually remember that the cooler got a little noisier, but thats when i thought to post a thread just in case I had done something wrong whilst using Speedfan.
I was using Speedfan to see if I could lower the speed of the cooler as it was too noisy(as previously said), since I couldn't do so within the BIOS, obviously that doesn't work. So I thought I was maybe doing something wrong or that my cooler could be faulty.
If the BIOS Q-fan is enabled in the BIOS, see how the fan runs according to what your doing on the PC.
For instance if its a cold start, the fan should run slower, then say you run Prime95 or a demanding game, as temps rise, the fan should speed up. Then slow down again as temps drop.
Speedfan can interfere with this and I would not recommend using it.
Let me know your Prime95 load temps, and disable speedfan for now and see if the fan is self-adjusting.
Speedfan has been disabled and when I start the computer, for the first few seconds the fan is quiet, but a few seconds later it's at full speed even with Q-Fan on. I have ran Prime95 whilst idle, but 24mins into Small FFT's test, it fails saying FATAL ERROR: Rounding was 0.4997558594, expected less than 0.4 - Hardware failure detected, consult stress.txt file. The temps I got whilst running Prime 95 were averaging between 42-54 i.e 42,44,41,38 - 49,46,54,47 albeit the numbers were constantly changing.
