Hi guys, My hpi Nitro Rush is tearing through the plastic large spur things. How do I stop this from happening? Im guessing the mesh with the metal cog is too tight maybe? But not sure how to adjust this.
Also another problem is that, at idle, its as if the throttle is fully open as it just flies off unless ive got the brake on.
I Adjusted the air flow so that there is less coming in at idle but that didnt seem to make much difference at all.
thanks Tom
thanks Tom
