R.I.P. Denon UD-M30
Man of Honour
18 Oct 2002
So after four years of faithful service my UD-M30 CD receiver decides to stop ejecting CDs. I will get a quote for a repair when I go home over easter, but I'm really expecting the repair cost to be too much in relation to what the unit is worth, so I'm looking around for other options.
I bought this before I was a poor student, and now I've become one, so money isn't around in huge amounts. Needless to say, I don't want to buy a piece of crap. I have no problem with buying Denon again, but the new M35 range look . . well, crap compared to the mirrored front of the M30 series.
I did consider just buying an amp, but I'd really like the option to chuck a CD in now and then, so I'm looking at receivers in the same kind of form-factor as this denon. I don't really want to go over £200, and I don't need speakers.
Thanks
If the drawer is belt driven then hopefully that is snapped and it will be a cheap fix, maybe one you could do yourself even?
Can you hear anything happening when you press eject?
Nah I've looked at it, pressing eject makes "Open" appear on screen, then it just re-reads whatever disc is in there. The tray is fine as I can take the front panel off and spin it open manually, it's just whatever controls it electronically is dead. There's no attempt that I can see by any component made to move the drawer.
