Hi all
Iv been using the R265 to print onto CD’s but I really don’t like the software. Its limited in the face you cant reduce the inner ring or even move the cd image to better fit.
Iv tried another package but it printed off centre and I ended up with half the ink on the cd holder.
Does anyone use another package and do you know the settings to set for correct alignment?
to do all my printing and in the Epson software you simply click the Icon boxed in red on the picture below: (You can then save the pre-sets for all your different printable media.
