I've been running 290 (non-X) crossfire since Friday night, and so far the experience has been faultless.
- performance is brilliant, currently running the 290's at stock and performance is 15% higher than with my 7970's at 1050/1500.
- smoothness is incomparable. I was very happy with the feeling of my 7970's at 5760x1080 (remember frame pacing only works on single screens currently), but after switching to the 290's, I realised just how much micro-stuttering I'd been putting up with without realising it. It's very much like when you have your car serviced after a long time, or give the house a really good clean - I've been running Crossfired cards for so long I had forgotten how smooth gaming can be until after I'd changed and saw it again.
- running stock fans at stock speeds, the cards honestly don't get very loud, certainly not as loud as all the forum comments made me expect it to be. Don't get me wrong, they're not silent when gaming, but equally I don't have to raise my speaker volume because of them. At desktop, they're quiet enough that I can't hear them over my case fans on their lowest setting.
- it's weird having my GPUs run at 95C each under heavy load, but as AMD have designed the cards to operate at that, I'm comfortable with this now. Also, because the coolers are stock and eject the air straight out of my case, my CPU and HDD temperatures are actually lower than they were when I was running Accelero/FrozR coolers on my 7970's.
- my plug-in wattage meter on the wall shows under heavy gaming (which on 3 screens with a liking for eye candy, happens quite a bit!) I am pulling 650W-700W, which is higher than the 600W-650W I was pulling with my 7970's at GHz speeds. I have seen 750W-770W during very difficult sections, such as the indoor bit on Sleeping Dogs benchmark, so I'm not overclocking until I upgrade my 750W PSU. Remember though, the rated 750W is power to the PC, not pulled from the wall (so 770W from the wall is only 654.5W of my rated 750W if the PSU is 85% efficient).
I wasn't planning on moving from 7970 CF to 290 CF, but my cards died unexpectedly so I was forced to make the jump. Now, I'm very, very happy I did. The measured performance is better, the perceived performance is night-and-day better, they're actually slightly quieter (remember, I'm not overclocking at the moment), the cards never go above 95C - which AMD have put in writing is a perfectly safe temperature to run at, and my other components are running cooler.
I'd definitely recommend at least an 850W PSU to provide a little headroom for overclocking, but they will run fine on a good quality 750W without overclocking.
