Dangerous Dave said:
			Its just the quickest way to tell if its working, I would be surprised if any R32 hasn't been launched that way at some point in its life afterall thats what the 4wd is for.
did it about 30mins ago, traction off, no wheel spin
but to the op, get over to
www.r32oc.com, sign up and ask any questions.
Reliability -, mines done 94k
 and nothing major has gone wrong. they reckon the 3.2 vr6 is only just run in at this stage
When you test drive one, you will notice there are a lot of squeeks, and rattles. DO NOT BE ALARMED, they are normal
if there is a rattle that sounds like a hamster wheel, that disappears when you press the clutch, thats a faulty flywheel bearing, and should be replaced under warranty.
One thing to find out is if its been on long life or normal servicing. Long life sucks, if its on it, get off it immediatly.
MAF Sensors are known to be a problem in the earlier models, can be bought aftermarket from BOSCH for around £60 and are easily replaced.
Invest in a VAG-COM cable, or know someone local that has one, its an invaluable tool.!
Anything else, you can get me over on r32oc!
