Upgraded a few things over the weekend ive had my eye on for a while Picked up a new monitor , cpu and a new case fractal design R4 ultra low noise.
Main reasoning for the new case was my corsair 500R was just too open fans and vents galore and was so noisy.
Now I setup the case it came with two 160mm fans (back and front) I removed the sound dampening panels at the top and fitted them there fitted two noctua case fans at the front.
At the rear is my closed loop cpu cooler fans mounted to the case.
At idle its fine but once I jump in game its still noisy and basicly seem pointless buying the new case now.
It sits on the floor next to my desk not much space im almost sat on top of it.
Sorry about my long story but my main question is if I removed the two top 160mm case panels and re-install the sound damp panels it would fixed the issue but im worried id be sacrificing cooling/performance.
Would my system still be getting enough cooling with out causing over heating?
any thoughts.
SPEC
990FX SABERTOOTH
AMD 8320 @ 3.8GHZ (PROB PUSH IT MORE SOON)
390X R9 ATI GFX
16GIG VENGEANCE
256SSD
3TB DRIVE
hope to get some ideas thanks
any thoughts.
SPEC
990FX SABERTOOTH
390X R9 ATI GFX
16GIG VENGEANCE
256SSD
3TB DRIVE
