Just updated my 2500k to an R5 3600 and starting to push the cpu speed up a bit
I had the [email protected] under 60°c on air for around 5 years without an issue, so now seeing if I can't increase the clockspeeds for improved single threaded performance for games (additionally testing to see how quick it will be for solidworks for upgrading the cad stations at work).
Using msi mortar max and a thermalright 140BW, case is wall mounted and open to ambient temperatures.
Still very new to overclocking modern cpus, last AMD processor I overclocked you needed to use a graphite pencil is bridge two tracks on the cpu
Currently I've got it sat at 4.4ghz all cores with 1.325v fixed voltage in ryzen master, it's run over an hour of P95 without an issue and temperature is 70°c peaks with it dropping to 60°c on the lower wattage tasks (still 100% load). Idle temps are about 32°c.
Obviously I will try to push the frequency up till it fails (temps allowing - want to keep it below 75 really) then wind it back a touch and see how far I can drop voltages.
Anything I should be looking out for? How far have people pushed these processors on a 24/7, some bits I read stated that they struggled for stability or heat much above 4.2 needing more than 1.4v.
