R6 Vegas
Permabanned
2 Apr 2007
Is it only me but can anyone connect to servers? I got this game 2 days ago and its fully patched and enabled on firewall etc but I can't connect to any servers I've went through the whole list. It just keeps saying it took too much time try again etc.
Yeah I have 1.04 and the game verifies that at the start anyway when you first boot up, I'll get a screen.
Tried about another 10 and still came up with that. Sometimes it will just come up with the match is no longer available but thats no doubt normal.
It looks like something is blocking the connection - i'd bet money on it. Don't just enable it in your firewall, disable the firewall completely.
Are you behind a router? If so, and you have NAT enabled, you don't really need a firewall anyway. You could try forwarding ports on your router, or adding your PC's IP address to the DMZ (but only do this temporarily as it exposes your machine to the internet).
^What ports do I need to have enabled for R6 Vegas?
Yeah I have a router, I tried disabling the firewall but still gives me that error. Im not on NAT. Im on DHCP.
what router you using? might be in a block list, windows or the firewalls.
have a looksi around, worse case senario is you have to reinstall it and keep a eye out for any programme connection blocks.
ags
SK07 said:
Im on DHCP.
Then you are using NAT (Network Address Translation - meaning you have internal IP address range seperate from the internet).
You will need to forward ports onto your internal IP address. Google the ports R6 needs, and Google port forwarding for examples.
