Banny said:how do you connect this card
do you need two lots of the PCI-E connectors
I.e one in the 8 pin hole and one in the 6 pin hole
or 1*6 pin connector into two molex's ( have tried this and it shuts off the psu
helmutcheese said:Thread is hear on that somewhere, if you want to get AXX to the ATI Overdrive settings to OC card higher you need 1x 8pin and 1x 6pin, but you can bridge the extra pins with a wire and it works, you could also OC with other software instead according to others here.
Banny said:I have tried plugging 2* molex in just cuts out psu, with one molex it just beeps
have 550w Antec truepower so should be enough
Two PCI-E connectors for PCI-Express video cards on 550W and 650W models, one connector on 430W model
