r9 270/270x
1 Dec 2005
Stoke on Trent
Is the difference between the two just the core speed? Im assuming either will be ok for bf4 snd cod ghosts at 1080p?
Just want to point out that while the 270 and 270x might seem the same, the 270 won't overclock as high due to the power restriction on a single PCI-E 6pin; the 270x on the other hand uses two PCI-E 6pins so it has more power to play with when overclocking.
Some 270's have two 6 pins.
I absolutely hate what they've done with the RX stuff, horrible rebrand imo.
AMD's reference spec for the PCI-E 6pin connectors is as I said for the 270 and 270x, but if board partners chooses to make the 270 with the same board/PCB as their 270x (7870), then yes of course the 270 would essentially be 270x with a lower clock.
Wee update, my two MSI 270 Gamings are now in seperate machines.
Both are running at a steady 450kh!
Think I can push the concurrency a tad higher too, but will try that tomorrow. Currently doing all my tweaking via teamviewer and had enough for tonight. Also want to find a way to up the core clock. They were both happy being slapped straight to 1050 core/1500 memory, but they won't let me set anything higher. Either way, impressed with a gain of 80kh per card for an hours tweaking. Happy to post settings if anyone is interested.
Sure this started in the crypto currency forum? Either way, my comments are less relevant than they were!
