- 21 Nov 2013
So yesterday i jumped the gun and bought a Sapphire r9 290 and an Accelero Hybrid.
I then spend the most of the day fitting the Hybrid onto my r9 290 with high hopes of better temps and low noise.
However this is not the case only for the latter
First of all my case is a bitfenix prodigy with a 140mm intake fan in the back, in the top a h100 radiator with 2x120mm as exhaust and then the hybrid radiator in the front as intake with 2x120mm in push/pull.
Im running an OC of 1100mhz core and 1400mhz on memory.
The gpu core is hitting 90-94 after a 15-20min of unigine heaven/valley and after 30mins of Black Ops 2 gaming it hits 80+
One of my vram temps is also around 85-90 when running 15mins of unigine heaven/valley.
These temps seems no better than the stock cooler and from what i've seen ppl with the accelero xtreme 3 cooler and the r9 290 have gotten a lot better temps.
Now i know that its a small case and the airflow is far from good but is it really that bad?
Or can i have made a mistake when i applied the thermal paste to the gpu core? or might the pump have been fitted too tight or too lose?
Also does the fact that the tubes, running from the pump to the rad, are really cramped due to lack of space from the end of the gpu to where the rad is placed in the front of my case, have anything to say about temps?
And could i have done something wrong in applying the vram heatsinks since im seeing such a high vram temp?
It also doesnt seem that changing the fan speed of the two 120mm fans on the rad does much about the temps, which i cannot understand..
I hope some of you might be able to help me out
