Your PSU is fine.
Does your motherboard support that FX9590 CPU? not all do.
I hope you have a high end cpu cooler as well, as that things runs HOT.
Not as bad as them 4790k's![]()
I'd definitely consider purchasing a better aftermarket cooler for that CPU Kupari.
Heat and temperature isnt the same. The 9590 puts out a lot of heat. 4790ks are easier to cool.
Heat and temperature isnt the same![]()
