- 13 Apr 2013
- La France
Does anyone know if the AIB partners now supplying own-brand card with non-refernce cooler designs make any changes to the fan control circuitry to cope with the current drawn by the extra fans?
I want to try using my HIS 290's on-board fan control circuitry (using After Burner to set fan sped/profile) and don't want to damage the card by drawing too much current for the 3 fans on my Arctic Accelero Xtreme 3.
To date, I've tried to manually set fan speed on the AX3 using the following methods:
- Arctic "7V" (Molex) cable : nice and quiet, but doesn't provide enough cooling to VRM1 when over clocking.
- Arctic "12V" (Molex) cable : plenty of cooling, but my OCD doesn't like the fans spinning 100% when the gPU isn't under load.
- Using my Zalman ZM-MFC1 fan controller : Despite getting a special cable made up, I've had no joy with this as the AX3's fans don't spool up. I suspect that the 7W (0.6A) per channel output of the controller isn't enough to kick the fans off.
If the AIB non-reference cooler designs do modify the fan control circuitry, I'll try another method such as making up a "10V" fan supply cable.
