R9 290 Stuttering
14 Nov 2012
Chesterfield
Running a reference 290 on a 1440p IPS panel and when playing BF3, stream off BBC and 4oD, I get stuttering.
Hardware acceleration is disabled and I'm running 14.2 beta IIRC - this may not be 100% but they're new drivers.
UPLS or whatever it's called is disabled along with power play.
Suggestions please?
For BF4.
Have you made sure you have unparked your cores?
http://www.coderbag.com/Programming-C/Disable-CPU-Core-Parking-Utility
Would also limit your FPS to 70-80 unless you play with v-sync then I would try 59 with v sync enabled. with the command code
GameTime.MaxVariableFps 70
bring up the performance overlay with the console command
PerfOverlay.DrawGraph 0
and if the yellow CPU line is still spiking have a play with the GPU rendera head limit command and what ever the settings is that controls the quality of explosions
renderdevice.renderaheadlimit 1
EDIT****
Just seen you have an 290, Are you playing with mantle? mine is so so smooth with mantle compared to DX, Smoother than my nvidia card was on DX even.
As Finner says capping FPS really helps i have an MSI 290X on 120hz monitor i play on custom mainly medium settings except for Mesh(Draw distance Ultra) and cap at 100 fps hardly ever drops below that and only get occasionally get a spike.
I think it's a driver/game thing. When I've played BF a few weeks back was fine, but in the past few days it was a mess. It actually helped if I've had no FPS lock.
