I wouldn't be surprised if you still got the same problem with the new PSU
Why do you think i will have the same problem.
It was an old 750w other companies own brand
There is a tiny switch on the side that faces you
Slide that across and see if that helps
Well all up and running fine now at last.
I was using gigabyte easytune6 for oc on the cpu and for some reason the system didnt like it with the new card installed.
I have now just removed easytune6 and applied a manual overclock and everything works fine. I am still a little put off with the Sapphire tri x though and with all the black screen issues i have seen reported with this card i am considering returning it and getting something else.
thoughts??
thoughts??
thoughts??
