I am looking at buying a 290 but the thing that is putting me off is the power consumption, is there anything you can do with the 290 to make it better? On a review I saw some tweaking options in the catalyst control panel but I don't know what they do...
The idle power is ok, but the power consumption watching videos (which I do a lot from my PC) is extremely high, has AMD released any new drivers since the launch that has fixed or improved that? If not is there any tweaks you can do to get normal power consumption when watching videos... for example "techpowerup review - Blu ray power consumption : GTX 780 = 18w, R9 290 = 75w, also the multi monitor power consumption is bad.
Is there anything you can do about this? Changing the power settings or changing the config files etc?
(no offence or negative tone intended)
