R9 290X Owners Thread
My asus has serious coil whine. Doesn't really bother me but it's there all the same. I know some people whinge about it . Only get it when the cards flat out on loading screens and the like obviously.
on standard settings
heaven in 3D
906 7950
1230 290x
nice 30% gain over my Overclocked 7950 !!!!
new driver doesnt seem to work for me in either valley or heaven - just get blank screen flashing the desktop every 5-10s, have to ctrl-alt-del/task-manager kill it. B3 was ok - unless I need to remove it all for some reason and reboot before installing.
Uninstall old driver, restart. Install new driver, restart. If you fail to do that then it may not work properly.
Definitely do a full uninstallation and reboot first, as sometimes files don't get updated properly otherwise and you may have a mix of releases.
Heaven 4.0
http://www.photo-pimp.com/gambrose/pc/Unigine_Heaven_Benchmark_4.0_20131025_2100.html
Unigine Heaven Benchmark 4.0
FPS:
46.3
Score:
1165
Min FPS:
8.0
Max FPS:
95.8
System
Platform:
Windows NT 6.2 (build 9200) 64bit
CPU model:
Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (3499MHz) x4
GPU model:
AMD Radeon R9 200 Series 13.250.18.0 (4095MB) x1
Settings
Render:
Direct3D11
Mode:
1920x1080 8xAA fullscreen
Preset
Custom
Quality
Ultra
Tessellation:
Extreme
Powered by UNIGINE Engine
Unigine Corp. © 2005-2013
I'm sure my CPU is actually at 4.5Ghz though...anyway, is that any good?
Scores below at stock 1000/1250, not going to push it too much now until I get my waterblock for it.
How do these look, I've not used these before so dont have any point of reference as to how it compares.
3DMark11
Firestrike (and others)
You have to compare the graphics scores but to answer your question, for a stock card the 3dmark11 score is huge and the 3dmark firestrike score is also very impressive.
Some other guy posted over 11,000 on firestrike on a stock 290X. That was on Windows 8 though i think. It was someone here, maybe in a different thread though.
