- 21 Jul 2004
- Harrow, UK
I have a wall mounted Allrack rack which has cut outs for fans at the top (screw holes at 100mm apart). None of the fan trays I have seen line up with these holes so I was thinking of buying two case fans, and using a UK 3 pin plug to molex power adapter to power them.
This would mean that the hot air is expelled directly out of the rack without just circulating inside.
Does this seem feasible? Does anyone have any better ideas?
