- 11 Jul 2004
- Neptune
Simple to install are they? Any major differences it would be worth me knowing about; i've not had much experience with them before.
Thanks
Thanks
BillytheImpaler said:All it is is a form factor, really. It's still the same ol' bits 'n bobs that you'd see in a tower server. The only difference, perhaps, is a lack of video out as most servers are administered remotely through SSH or some other remote shell application. However, most have a VGA port and support at least VGA resolutions for when you're performing your initial setup.
If you're talking about installing components, it's pretty much the same as your run-of-the-mill desktop system. Things are usually arranged a little differently, and you will have to use riser cards and low-profile heatsinks if you're using a <3U (I think) case, but otherwise it is the sameTried&Tested said:Simple to install are they? Any major differences it would be worth me knowing about; i've not had much experience with them before.
Thanks
