Update: Concluded in post #9
So we're in need of a shelf in our rack at work to allow us to put a couple tower machines in there. Thinking this would be a reasonably straightforward purchase, I measured the depth and ordered a shelf. I've just come to fit it though, and it's too wide. The width of the shelf is 483mm (standard), however that's the width of the entire shelf, not just the front and back bits, the entire shelf, so it can't physically slide in? Here's a picture that I hope demonstrates my point (click for bigger):
Here's a picture of the sheet of paper that came with it, explaining how you're supposed to fit the shelf:
Am I completely misunderstanding the situation? Because as far I can tell, even if the rack was open, and we fitted it to the four corners, the shelf would still collide with the central rails pictured here:
Best I can tell, I'm in need of something more like the following, with the mounting points wider than the physical item, and therefore more akin to a switch or patch panel:
Does that seem about right? Appreciate the help
