Rad 9550 2nd Ed OverClocking?
Permabanned
23 Dec 2004
Redhill Surrey
Hi all does any one know where i can get some soft mod or over clocking software for the above?
Also i heard that i can update the Bios to a Rad 9600 this true???
HELP so lost :confused:
The 9550 has a lock put on it by Radeon. Get ATI tool and remove the lock. The core is a r360 so will go over 400mhz and run all day.
The memory is the poor part of the card with some only going up very small amounts.
Should get the core to 400mhz easy and the memory if stock 200mhz will only get up to 210 or poss 220 at a push. Some of them do come with memory set at 250mhz if lucky.
You can flash the card but make sure you pick the correct bios or u in trouble.
Good luck
