i use the Pro but could just as easily have used the LT and hidden it away somewhere.
all the screen does is tell me the time and i configure the software in windows.
overkill imho but you can never have too much rad space
a 2600k and a 580 would be fine on any triple rad so take what you will from that.
for silence, i would suggest a ddc 10w. this pump is small, compact and offers excellent flow rate. couple it with an after market top to increase performance and allow you to use uniform fittings throughout the loop, you will be onto a winner.
reservoir wise, a single bay xspc jobbie will be fine. maybe look at the alphacool tube reservoir too. I have one of these in my build and was surprised by the great quality, especially for the price.
fittings and tubing, i would probably go for
this and this if you want thicker tubing
or
this and this if you want slimmer tubing
each of them will have no impact on performance so just choose what you like the look of best
140.3 and a 140.2 rad to cool an overclocked 2600k and overclocked GTX580
or
