- 16 Nov 2010
- Swimming in a lake
Ok, whilst I understand (roughly) the whole fins per inch or whatever it is, I'm looking for some help
Basically, I'm still planning my wcing ideas in my head - may be a while before they materialise, but figure that rads and the such like can't advance tooo much in 4 months.
So, I'm looking for a few things requirements:
It's not particularly about cooling. I'm not going to be running a huge overclock. What I do want is silence (my 480 is doing my head in). Or as damn close to it as possible. If the PSU/HDDs is the loudest thing in the case I'll be happy.
Now I'll be cooling, CPU + anywhere between 1 GPU and an SLI of 2 GPU's. Might go for a 590 or similar. But I figure if I want to future proof, 2 GPUs should be the max I'd need.
Now, I'm thinking rad wise, I might start off with just CPU, so a 240, but eventually I'll be looking at anything from about 600 up to about 840 (total obv)....
Now I'm well aware that 840 would be complete overkill, however, it would mean that I could run much much slower fans or the such like, and try and get as much quietness as possible.
So what Rads, and what Fans are we looking at? Are we still thinking GTs? Or would something like some Noctua's actually be better? Price is something that isn't too much of a concern, however I might look to second hand fans or something, but that doesn't really matter, I just might have to clean them up first...
Also, quick question with regards to Rads and 2nd hand. Is there actually any issue buying a rad second hand? (so long as it's not spouting leaks all over the place)? I'm kind of presuming it's quite a hard thing to wear out, and doesn't really need replacing or upgrading anywhere near as frequently as other stuff....
Edit: Also, something that's always confused me is where as most people have curves in their watercooling, some people's are perfectly straight. Is this just a case of very careful planning, and some good 45degree fittings and the such like - and could you suspend a fitting theoretically in mid air from two pieces of tubing, to create the illusion of two pieces of straight tubing with one fitting in the middle?
kd
kd
