Hi, trying to mount radiator inside front of case to the cases frame but the drain port is clashing on the base of the case, raising it too high to align with fixing holes of case.
Should I try drill a hole for the drain port to fit in to OR buy a rad with no protrusions on the bottom? (if there are any)
