Im going to be mounting a heatercore in the top of my pc in about 2 hrs, and ive got 2x120mm fans fitted to it.
I personally think that i should be having the fans taking in air and blowing air into the heatercore.
I know that this is bringing air into the system, but i have a 120mm exhaust fan at the rear of my system too.
Is this the best way to go, or should i have on intaking one extracting, or both extracting?
Any help would be great thanks.
. My point was (not very well explained) that you will not raise the internal temp much by drawing air in though the heatercore so don't worry about it.
