I have a TFC 240 RAD with 4 Scythe 1900RPM fans in push/pull and my temps seem a bit high.
Im only cooling my CPU a Q9550 at 3.8Ghz Vcore 1.37V and my temps are idle 40ish upto 60 under load (prime or OCCT) so a 20C delta.
So should i be running in push/pull?
should i get rid of the push and fit some shrouds?
do i need better fans? Kazes?
is it better to be blowing out from my case or sucking in ( i have a CM stacker 832 and im pushing out through the drive bays)
(can post pics of set up if needed
sayso
*i have posted on FESER USA website forum but still no answer
)sayso
