rad fitting in a 650D ?
7 Nov 2002
pantyhose factory
looking at possibly picking up a 650D so i did some research to look at various watercooling options. Originally I was going to go with my current CM690ii but due to various reasons I am going to change cases anyway now.
Having looked at different build logs across the internet there is one thing I still can't work out because no one seems to mount a rad here, but can you fit a 240 in the bottom of the case ?
I was thinking of a 240 in the roof and a 240 in the floor. Roof one seems pretty easy, might have clearance issues if I run push/pull but if I am using a 30/35mm thick rad I reckon it will fit.
