Rad help
16 Oct 2005
Which radiator (1/2") is the best for mounting where a 120mm fan would usually be? Cant't find the right thermochill one that fits if there is one? Will be using it with an amber fan.
take measurements as the thermochill rads especially the PA ones are pretty BIG, and i know some people who bourght some and then found out they couldnt get it in where they wanted.
I would use a diff fan on that though! one with a bit more UMPFFFF.
Panaflo on a 7v line. if you use amber i would have two, Push and Pull
