Hey ive got a triple rad i want to fit for my first water cooling build, i was wondering is it best to try and mount it on the back of my cosmos case or inside in the top as there is enough space, i just loose a drive bay. Also how exactly does it mount ? i cant see screw holes or provided screws that are bug enough im a bit lost on how to fit it.
thanks !
thanks !
