Hi all
I’ve got a x72 kraken attached to a g12 nzxt bracket on a 2080ti with 3x 120 Thermaltake riing white LED fans on one side pushing air through the rad.
The rad is mounted vertically in an Lian Li o11 dynamic.
I’m thinking of adding 3x additional fans to the rear of the rad (mainly for completeness and because the case accommodates it so well) but was wondering what I should be looking for fan performance wise.
Would it matter if I use air flow or case fans to attach to the back of the rad or should I still be going for static pressure fans?
Not looking for rgb / led as I’d rather keep the back of the case unlit.
I was thinking some cheap nzxt 3 pin case fans in black might do the trick?
I’ll post some pictures of what I’m talking about shortly.
Edit: I have a phanteks fan controller so 3pin are no problem speed adjustment wise
