Rad recommendation
15 Aug 2008
Birmingham
Looking at putting in a loop to cool my CPU & GPU (specs in sig). I've got everything I need sorted except for which rad to use.
I don't want to have to mod my case (antec 1200) unless absoultely necessary, so I think its going to have to be mounted externally on the rear.
I've been looking at the Thermochill PA120.2. Would this be enough to cool both my CPU & GPU?
Also what (if anything) would I need to buy to fit it exterannly on the rear over the 2 rear fans?
That case is less than ideal for internal WCing if i remember correctly, look at the swiftech Radbox which allows external mounting.
yeah I've looked at that one. Only problem is its out of stock & OCUK have no idea when they will be getting more in
