Rad temp - will it hit 40c?
Permabanned
28 Mar 2011
Space Man INIT
PC specs
AMD X4 OC'd to 4.4Ghz
Asus CHIV
Corsair Doms
2 SSD's
8 140mm Yate Loons
2 Laing DDC's upgrade PCB DYINK
2 5870 in CF
Cooling setup
EK-Supreme HF
EK-FB ASUS Crosshair 4
EK-RAM Dominator
EK-FC5870 V2
Black Ice GT Xtreme 560
Custom 30mm shoruds X2
Tygon R3603 3/8"ID (1/2"OD)
1/2'' G1/4'' Fatboy Barbs All Round
EK-DDC Dual Top V2
2 18W DDC (DIYINK PCB's)
Swiftech MCRES-Micro Reservoir V2
I'm thinking of a different means to control my fans. The 2 controlers i have tried do not work with the 8 Yates. So though about thermal control. Sticking a thermostat switch that works at 40c on the rad fins. When the system hits 40c it spins the fans, when it drops to 32c fans power off.
think the highest my rads have hit was around 36-38. Sensors placed behind mobo around the board have been between 30-48 though, depending on placement.
These temps are the highest I have seen though, on a hot day in a room with poor ventilation while gaming. Normally none of the sensors on my rads or aroudn my pc that werent on components would go above 36.
that is with yateloons ds12 on my rads, at full speed though, so I imagine it will hit higher with them off.
I would have thought the you'd still be better off trying to control the fans by the cpu temperature rather than the water temp. Is that not possible on that mobo?
The fans draw a lot of power so trying to use mobo to control not at option. The less running off the mobo which in my case is nothing the better, more stable i find.
The idea is fan off system heats up, rad hits 40c fans kick in then once back to cool temp fans off again. Like on your car
