Hi,
I posted on here recently about ideas for a graphics card upgrade and one card suggested was the Sapphire Radeon hd5670 1gb gddr5 card. So after looking around at the others suggested I bought one of these.
It arrived today which was great as my curent card which was what caused the upgrade (radeon 2400 hd xt) has a broken fan, still spins but is missing half of it. Anyhow, I followed the instructions in the booklet - uninstall the current card, turn off and replace it with the new one. This was fine, except once the 5670 is in, I start the pc and the monitor says no monitor signal. The pc appears to then grind to a halt. After a few unsuccessful attempts at restarts I put back in the old card, windows loads and attempts to update the hardware which then cuses an instant shut down. One of the issues thats been happening with it, the card heats up far too fast and causes these shut downs when I am in safe mode too. Its making it very hard to uninstall it and install the new card drivers (suggested through googling the problem). To make it worse the 2400s plastic pins that hold the fan piece in place fell out but I fitted them back in so it at least holds it together.
Also I used the adapter to plug the monitor into the new card as the pins are different.
OS is Win xp SP3
2GB Ram
Motherboard - Lenovo thinkcentre m57p
Monitor - ViewSonic VA2213W with up to date drivers
Not sure of PSU - did ask on the previous topic but no help given.
Not sure what else to write as I am currently using my laptop due to the constant shut downs on the main pc.
Please can anyone help, I've had a load of bad luck lately with this old card and its really starting to get beyond a joke. I just want to get on the computer without it shutting down. Please note I don't have a third graphics card to use - the 2400 is the only one that works technically and with its constant overheating its not looking very good.
Thanks, Howard
OS is Win xp SP3
2GB Ram
Thanks, Howard
