Radeon 5850 overclocking problems
3 May 2009
Hi
I'm going to get MW3 and Assassin's Creed Revelations when it comes out, so I thought I would try and get more juice out of my MSI Radeon 5850 Twin Frozr. I've already got a mild overclock of 800Mhz core and 1120Mhz memory, which I've been playing F1 2010 and Assassin's Creed 2 on with no issues. I used MSI afterburner and furmark and over clocked the core first to 870Mhz and then the memory to 1180Mhz, with no issues at all. Furmark was set to 1024x768, xtreme burn mode, post fx on and no aa. But both games didn't like these settings one bit and crashed the driver straight away. By the way I'm running 11.10 driver only, no ccc.
I've seen guys getting stable overclocks way higher than that so any ideas? I don't want to upgrade the card yet as I'm hanging on for 7000 series.
Full spec OCZ Mod xstream pro 600w, Giga-byte MA790XT-UD4P, AMD Phenom X3 720 @ 3.1Ghz, 4GB OCZ OCZ Platinum DDR3 PC3-10666C7, Western Digital 320GB HDD.
Have you raised the volts
im not sure how you do it on ati cards but can't be that hard.
When you find out if you don't know tell me and ill do it to my 5850 on my second computer
edit: on my other computer now and looked at what i clocked it to.
core 875 mem stock
thats as high as it goes i think on stock volts. never really messed with it that much. think i tried 890 and it crashed
ive been messing with my saphire 5850 as well recently and ive got the core at 899mhz and the memory at 1200mhz and i cant change the volts so all stock volts, been running bf3 and 3dmark 2011 and unigine and touch wood all seems fine so far!
when i have time ill give it a go. flashed a few cards.
last card was a gtx460 with the fan speed set to either 30 or 40 % at idle and i could hear it so flashed it to 20% lol nice and quiet now
use smart doctor. you can set the volts then.
just trying to work out how to do it with msi after burner
smart doctor looks like the skin has not been updated since window 95
edit: testing at 900 core
edit 2: smart doc only goes up to 900 core. so thing you have to have msi open as well. clock with that and up the volts with smart doc. there must be a better way. anyone?
I'm able to change the volts in afterburner but dont really know what I'm doing with that side of things so I've never touched it. It's showing 1164mv at the moment, what do u think I should put it up to, with 870/1180??
I run mine 1.25V for 975MHz, requires 1.3 for 1GHz. Mine seems to be pretty volt hungry as I've seen other people get 1GHz on just a tad over 1.2V
thanks for all the suggestions, I'll have a go at upping the voltage a bit tonight and see what happens.
elrasho - Yeah I have been thinking recently about getting another 5850 but it will have to be second hand wont it? Don't see any new ones out there. Would my xstream 600w psu take two cards though?
Post a link to your psu and ill see
Yep that should fine. I have a Corsair HX620W and it pulls 400W under load using both cards. What motherboard have you got? We have to make sure both PCIE slots will run at 8X under crossfire.
You motherboard is fine:
1 x PCI Express x16 slots, running at x16 (PCIEX16_1)
1 x PCI Express x16 slots, running at x8 (PCIEX8_1)
Which means the PCIE slots will run at 8X under Crossfire :) Yes get a second hand one, some shops sell them new but for £160 as they are hard to get new. I sold one for £80 in MM which is about the going rate. You'll see a massive performance increase (I saw literally double in my benchmarks and FPS in games!).
