I have a Radeon 9550 Rv350 core with 256 ram 128bit 4 pipe line card.
I have read on some sites that you can change the bios of the card to make into a 9600 card that is not locked as 250GPU & 200Mem.
I know this GPU can run faster as read some people have clocked this as high as 400mhz.
I want to change the bios and make it so I can clock this card as it is currently locked.
I have got ATI tool but wont let me save the settings when clocked so when pc restarts I have to reclock the card all the time.
The card is a basic on with no fan on it but a cheap heat sink on the GPU.
If anyone could give me the a suggested bios upgrade to remove lock and ture core to a higher default.
GPU was clocked at 400 stock afterwards and the core is recognised as as RV360 (9600) rather than the 350 (9550) and will run stable at 450mhz all day long, have set the day to day settings up in Ati Tool as 410 gpu and 200 mem.
