I have a Connect 3D X1800 XT which I have never overclocked.
I think the stock GPU speed is 621 and the RAM speed 747.
This evening I got an alert saying that the GPU was over temperature and that the ATi utility was automatically reducing the the GPU clock speed.
I've given the computer a good clean out and the card is now running as follows
GPU Requested - 621
Current GPU - 594
RAM Requested - 747
Current RAM - 693
Current temp = 53 degC
So I have some questions
1 - Since it is running so cool why won't current clocks rise to the requested values? Is there a way of forcing back to stock defaults (selecting the 'defualts' button doesn't help.
2 - Ideally, I'd like to take the heatsink off and reseat it with some fresh Arctic Silver. What's stopping me is the sponge pads on the RAM. I assume they are double sided sticky and I will have to damage them to remove the heatsink. Is this correct? If so where can I buy some replacements - they around 2mm thick not the tape.
3 - The alternative is to buy a new heatsink. Is the Akasa VC03 a good choice
http://www.overclockers.co.uk/showp...ame=Akasa AK-VC03-BLUV Vortexx NEO VGA Cooler
Would I see an improvement over the stock fan?
Cheers,
Nigel
GPU Requested - 621
Current GPU - 594
RAM Requested - 747
Current RAM - 693
Cheers,
Nigel
