Just a heads up, don't push it to far with out a custom cooler on it there great cards but they do get hot fast.
(wife will not be happy)Yeah you can push the clocks as much as you want and it won't damage the card. The only think that will damage the card is putting too much extra voltage through it. Also adding more memory doesn't really add to increased performance I've found. Stick to maxxing out the core clock first.
It should do 960mhz all day long just fine it's the memory which tends to spaz out first
Been running my 5770 for years @ 960/1300 with no problems what so ever just remember to bung the fan on manual and try and keep gaming load temps under 70c
