HI guys i just played bf3 for the first time and was dissapointed to find out it is running at 30 fps on low settings! while i expected around this fps (pc is 5 or so years old) i thought it would be manageable but well it isnt.
Im looking to upgrade to a Radeon HD 6850
Currently i have
Asus p5k deluxe mobo
Nvidia 9800 GTX (512mb)
Intel q6600 @ 2.4ghz
4gig ocz ram
Now my question is 1)will it be suitable for the motherboard? i read that the mobo is only pci-e 1.0 but you can use pci-e 2.1 on older mobo's just wont be at full potential.
2) Im also looking at over clocking the cpu to 3.0 ghz ive read on forums that the cpu shouldnt be so bad and its more my current graphics card.
Looking at benchmarks this card performs rather well so if im able to afford a full upgrade in the future i may be able to leave this card in for a while?
Im not looking at amazing results by buying this card alone, im just looking to raise it to level which is playable (not so bothered about graphic quality at this stage) will this do it or will i be held back by something else ??
many thanks
Currently i have
4gig ocz ram
many thanks
