Radeon Pro - Dynamic Vsync
Caporegime
8 Sep 2006
On Ocuk
Has anyone had any luck in getting Dynamic Vsync + Arma 3 working together? I would like to have the adaptive vsync style setting in the Arma 3 game and breaking point, but when the API is enabled it stops the games from loading with a crash. Turning off API monitoring and the game works, but then there is no Dynamic Vsync
EDIT : Forced VSYNC in Radeon Pro set to 64bit mode, retried and still it's not working as the frames are going above 60 and tearing
I find Radeonpro to be quite tempremental at times. Some games it will just work, others I have to fiddle around with it. What I have needed to do with some games is exit it, then restart it in administrator mode - it will come up a warning saying it's not meant to be run as an administrator, but you can ignore that. It may work doing that, it may not. It certainly worked for me on COD Ghosts and a couple others.
All my applications, games etc are run in Admin mode, so it's not that :(
I miss Nvidia's Adaptive Vsync as it worked with EVERY game
Ask the creator. https://twitter.com/radeonpro
I'll direct him to the thread via twitter and see what he says old boy.
Well then that MIGHT well be the problem. I have found it to be hit and miss with which games radeonpro gets on with when run in admin mode. It really is trial and error I have found. On Windows 8.1 certainly. Don't think I had such inconsistency on Windows 7.
I'm using windows 8.1 and i do use RadeonPro on a few games. I'm the only account on this computer as well so definitely admin.
RadeonPRO is in admin mode and works on skyrim but it causes Arma 3 and even the breaking point launcher to crash as soon as it's loaded with an appcrash. If the api is enabled
