- 25 Apr 2011
- Crawley/Gatwick
Bought the card on that Mega-Deal few days back
Gave it a go on a clean OS (win10-64)
Unigine Valley 2900ish on extreme HD, which is 400 over my EVGA GTX970 SSC. Pretty impressed with the performance to be honest
Card isnt too loud, heard much worse. In regards to coil whine, i cannot hear it, yet. Fans are low and normally whine is audible
Power draw seems to be reasonable compared to what AMD normally has
Temps are 83 under load, perhaps will go higher in BF4 gaming
Dropped down to 81 with a closed case, cudos..
Cougar QBX has a terrible intake so not a massive surprise
Anyone else with feedback? What are the max temps before it throttles?
In Unigine Valley temp readings are always wrong or absent, should i be worried?
I did have a fuzzy screen after format, but i think thats becouse retarded win10 installed old catalyst app
Ive uninstalled and all seems well
just use a on screen display to show the proper temps and what not.
