Hi
Ive just installed a GIGABYTE Radeon RX 460 WINDFORCE 2X OC 2GB GDDR5 Graphics Card but comes up with no signal for both hdmi and dvi. Cant get into BIOS or anything. It's not booting either at all I dont think. Its fully seated and connected properly. I cant tell if card is getting power as I know fans doesnt spin anyway when idling. There are no lights coming on.
I put the card that was in there before (nvidia gt520) back and it runs fine. System has a gigabyte motherboard, core i3 and Corsair 430W PSU. Card does not require 6 pin connector as runs on motherboard power
Motherboard is Gigabyte GA-H61M-S2PV (Rev 1.0 I assume) It says UEFI BIOS in the BIOS screen. Is from 2012. Could it be that and needs BIOS update? Dont really want to do that as will prob invalidate warranty on PC if it goes wrong during flashing.
I might be best just returning and getting an older equivalent i.e. GTX 750 Ti, or something. Sure that'll work
Thanks in advance
Masten
Thanks in advance
Masten
