Radeon RX 480 Nitro+ 8192MB GDDR5 PCI-Express Graphics Card problem?
8 Feb 2015
Got a friend who wants to put a 'Radeon RX 480 Nitro+ 8192MB GDDR5 PCI-Express Graphics Card' into his pc.
He has a Asus M3A78-EM motherboard and a AMD Phenom 2x4 940 3.00GHZ cpu.
Is this a good idea or will there be ter-rouble?
Joking aside it should be fine with a decent 500watt PSU.
I'd advise your friend to go for the £199.99 4GB version of the card.
Their CPU is too old to properly feed a graphics card this powerful, and 4GB will be fine for 1920x1080 and below for a couple more years.
That CPU would struggle to tap utilize even 50% of the performance of that card. And also as others already pointed out, it's also depending on if his PC has a good quality PSU.
Should work fine if the PSU is of reasonable quality. The main issue your mate will have is the weak CPU holding the card back badly.
Im running my overclocked RX 480 with upped power limit on 350W power supply no problem.
But that's only with i3 4330 although I got i7 on the way as the i3 is bottlenecking it in many games so we'll see if the power supply can keep up with that.
Brilliant. Thanks for all the help. a lot of info here.
This is the original post that brought about my seeking help, btw.
http://thenitwitts.enjin.com/forum/page/1/m/28206608/viewthread/27295925-new-pc-specsany-ideas
He wanted to update his pc to be able to play Titanfall 2 reasonably well.
I was looking out for a card to update from my i5 4670K/R9 280X/16MB pc as well and I just told him about the Nitro 480 as a possible solution.
Nice friendly helpful forum you got here.
