Radial distance from multiple x and y coords Excel
23 Oct 2003
Cornwall
I apologise in advance if this is a really simple thing or Google, but I have been drawing a blank now for several hours and can't get a workable answer off of Google.
The crux of the problem is I want to calculate the distance of a load of points (using Pythagoras) in a grid from the centre point, similar to that below.
Code:
   A    B    C    D
1 1.41 2.24 3.16 4.12
2      2.83 3.61 4.47
3           4.24 5.00
4                5.66
So cell A1 is 1m in the x and y direction from the origin so SQRT(1^2 +1^2)=1.41... similary D2 is 2m y and 4m x direction so SQRT(2^2+4^2)=4.47 and so on.
It is easy enough to do for a small selection of cells like that above, but I need to do it for approx 100 values in both the x and y direction and on 360 degrees (or at least 90 degrees - I can hack it from there) not just 45 degrees in the example above.
So can any of you suggest a way to easily do all 10,000+ calcs without doing it manually in excel, or even direct me to a somewhere that has already done it?
If you're interested in the background of the problem, I have been asked at work to produce noise calculations for several different scenarios which involves the calculation of the combined noise in dB (e.g. 84dB + 85dB = 88dB) and then how this dissipates over a large area - and all in accordance with BS5228-1:2009. To plot a nice surface graph I need to calculate the power at all the given distances from the assumed origin. I'm going a little beyond the required answer here, but I'd rather produce an easily editable spread sheet rather than one-off hand calcs.
Far easier on something like MATLAB or Mathematica if you have access to such programs.
Also, what do you mean by 360 degrees, I don't entirely understand the question :confused:
Do you want to have the answers for z = sqrt(x^2 + y^2) where x and y range from -50 to +50? on a speadsheet?
Ah, should have made that a bit clearer.
Essentially I need to have z = sqrt(x^2 + y^2) from -100 to +100 in both the x and y directions.
I am assuming that the sound sources is at (0,0) and want to calculate all the distance from orgin in a 1m x 1m grid for from (-100,100) to (100,-100) i.e. top left to bottom right, so I can then use this in my sound decay calculations.
Well, I don't have a clue how to do it efficiently
But I've done is brute force
I'll Message you via trust and send it to you if you want.
Basically I copied and pasted the numbers 0-100 101 times horizontally, and then again vertically and used them for the function. Really really not elegant but meh, killed some time. The numbers you want are in bold btw
