- 12 Jul 2004
- Poole Dorset
Firstly my setup now -
AMD Opteron 180 @ 2700Mhz 10 hours Prim95 stable.
DFI NF4 board, 2Gb OCZ ram.
Laing DDC1 with Alphacool top and Thermochill HE120.2 with 2 Nexus fans running at 7/9v.
I was running a AMD 4000+ San Diego core on the above but with an Eheim 1048 pump and cooling just the CPU. Temps where never higher than about 43c in a room with ambient temp anywhere from 20 - 30c Radiator had 2 Panaflow 38mm deep fans).
Now, in my search for silence, I have rehomed it all in a Silverstone TJ07 and put in the Opty and waterblock on the Northbridge. Now my idle temps on the CPU are on average core 0 = 28-32c and core 1 = 31-36c. However when running OCCT for 1 hour temps on core 1 hit 62c. (Worried? yes I was).
I think the problem lay with the rad and fan setup and would like to know if it is worth the investment to switch to a Thermochill PA120.3 and see a significant difference or what advice on radiators would people give. Are there any better than the thermochill?
Ive just ordered 2 water temp probes to monitor temp before CPU and just before entering the rad.
Setup due to pipe length and space is res > pump > CPU block > northbridge > rad > res.
Just a thought, do you think I would be OK putting the Panaflo's back on to pull as well as the nexus to push?
